oh wow! confused again.
you said to use an Rx pack...it's just a 5cell, not S. I thought that I 5S lipo was a 5 cell. Please correct me if I'm wrong.
Yes, 9 servo's is a lot of draw. I'm doubling the servos on the ailerons because each aileron will be 60" long, so that's 4 servos right there.
I have a BEC, my first experience with an external BEC, on my 60" wingspan motorglider and all works well. If I use a BEC on this BIG plane, why would I need an extra 2s or 3s battery?
I just read the details on that BEC that you suggested. I see that the BEC has it's own battery hook-up. On my motorglider, I have my external BEC soldered to my main lipo pack. That's why I was confused about that part. There is just so much that I don't understand but I'm really glad that I'm still building this plane because of all the other stuff that I'm learning.
Thanks Tony and I'm sure that I'll be back to harass you some more.
You said, "If you want to use a BEC, then you can run an extra 2s or 3s battery as big as you want. Just make sure the bec is rated for the amp draw of your servos. 9 servos is a lot of draw so do your math." A lot of the servos that I've looked at recently don't say anything about amps. What am I missing? I'd like to be able to do my own math, but I honestly have no idea what it is that I should be looking for. it's probably something simple that I'm overlooking.
