The wife and I, especially the wife, is very fascinated with your photography. Some awesome pictures that you share with all of us Randy. Keep up the good work!
Question... when the eclipse show up in Aug. Can I view the eclipse with my quad and my FPV goggles without hurting my eyes or would you not recommend this? We have glasses coming from this place
Science Supplies & Curriculum - STEM - Chemistry but I would like to record the eclipse from my quad, just for s_ _ t and giggles. Thanks again for sharing your pics.
As long as you place a solar filter in front of the camera lens.... you probably can but how good it'd work would depend on the camera, it's len's diameter and the sensor it has.
I made my own filter for my camera... I simply took a basic clear glass UV filter ( 62mm, actually a little larger than the diameter of my lens which is has a 58mm lens and a 300mm focal length ) and then a sheet of mylar solar filter film... I cut out the mylar to the diameter I wanted ( slightly larger than the 58mm ) and used a little water with a little bit of liquid soap in it ( just like you'd use to put film on your car windows ) and put the mylar on the front of the UV filter. I then attached the filter to my lens using an adapter to take it from 62mm down to the lens diameter of 58mm. I used an oversized filter so when I cut out the mylar.. any gaps I made wouldn't be in frame of the lens.
I could have probably just made a cardboard frame and then somehow fix it to the front of the lens but I didn't want it to get in the way of the focus.
Using autofocus was a little soft... to get the latter shot, I had to manually focus it instead.
The 8"x8" sheet of mylar solar filter cost me about $20 on Amazon... plus the other items I got.
The only way to know if it will work well for you using the camera on your quad... is to try it. Just remember that if you can't zoom in... the Sun will be pretty small in the picture. If you want to see how small.... do a test run using the Moon which is the same apparent size in the sky.
Another possible way to do this... is to use a sheet of paper that you've poked a hole in ( cardboard or construction paper would be best since they are stiff ) ... and project it onto another white sheet of paper. You can actually do that now even before the eclipse just to get an idea of how it'll work. I suspect you'd even see the sunspot with it. That's what I used as a kid to get to see a partial eclipse with long ago.
