DISASTER!!!!
Well it had to happen. After more than one year, i have finally put the 600 in.
I can take full responsibility that i dumb thumbed it. Gave too much collective in a Piro flip.
But one very strange thing happened. I actually recovered just before it hit the ground. But then suddenly after centring the sticks it flipped over in a split second and hit the deck inverted and hard????
I mean it was as if the controls were behind what was actually happening.
I'm a bit confused and can only say, I got away with things lightly.
This was buried into the ground when i went to pick it up. Tail was caked in mud, landing gear was broken off.
Once i returned home and stripped it down, the only things broken were:
Main Blades, Vertical stabiliser, Base plate and 4 teeth on the main gear. Oh and a couple of cracks in my nice canopy
This bird is amazingly strong. No shafts bent, nothing damaged in the tail, even though it dug a hole in the ground.
Well it may be benched for a while as i can't afford to get the blades just yet. Everything else i have here.
I am doing a thread about what to check after a crash.
