Power Supply's Portable power supply
Hi grayham that looks great the blue looks fantastic and the case is small i like it. Cml001 another great looking case i love that you can see inside looks cool both great jobs happy flying. :wavey:
Hey Tony,
I watched the video and was courious if those 2 grounding pins have to still be snapped off and the screw with the installation paper and glue have to be sdne still if your only using 1 power supply only? Thanks.
If you are only using one supply no you don't have to isolate the Dc ground, if you do want to use two in the future the second one in series has to be floated (dc ground isolated) and you should not use that one on its own,
Hey Tony Thanks for all the help and info on all this and everyone on the forum I did mine a little different..... kinda like an old school reactor box. 2014-04-06 14.02.43.jpg
Just wanted to say thanks for all the insight! .....
Sweet, Thanks for the info SLOBBERDOG.
Ok, this is the power supply that I got (sse photos). Now I have plugged it, got power but nothing shows up on the volt meter. What am i missing?20140407_150009.jpg20140407_145950.jpg
It will come on (fan will run) ... you have to connect the pins (or short out the pins in the front to get the juice flowing .... look through the pages on this Forum Post there are a ton of diagrams that can explain it far better than I. I am not sure on the Dell but there are HP Diagrams everywhere and Tony has a great YouTube video on it.
I guess i didn't do that but here is the thing, Its a 24 pins not 9. So which pins do is short out?
Aw :):):):), jsut saw the pics again, Same amount of pins just horizontal compare to vertical. Duh
Hi Redwings
I have had a look around and it looks like you need this diagram to short the pins,
N N N N N Y
N N N N Y N
N N N Y N N
N N N N N N
It's from someone off another forum that's using the same power supply
Aww sweet bro. Dose that diagram slow the fan down as well or would it be the same as the other configuration ON A 12 PIN?
thanks
Hi Redwings
N N N N N Y
N N N N Y N
N N N Y N N
N N N N N N
thanks Just sent you a Pm on the same question. I'll try it, most can happen I could trip my breaker in my power bar I hope.
YA, saw the video only problem is his power supply has 12, pins, mine has 24 pins. Just trying to work out the kinks with another forum member now. Thanks
Tony,
I have seen your video , bu I have a problem. I have a 24 pin power supply, so which pins would I shot out to get the same results including the fan? See pics for details. Thanks
Thanks SLOBBERDOG for the advice, Just wondering if the same pin configuration will work on a 24 pin set up. I'll test it and see. What could go wrong.
N N N N N Y N N N Y N Y
N N N N Y N N N N N Y N
N N N Y N N N N N Y N N
N N N N N N N N N N N N
