Power Supply's Portable power supply
Slobberdog
When you have copied the table I gave you, you have doubled it, the diagram I posted is for your 24 pin config for the power supply that your using
So join the "y"s
N N N N N Y Top row of 6 pins
N N N N Y N next row
N N N Y N N 3rd row
N N N N N N none touched in this row
hope this helps a bit more
redwings
So join the "y"s
N N N Y N N 3rd row
No problem, I got the last diagram , I just tried to post the other diagram with the fan cut off beside it. I guess it posted directly beside yours.
redwings
Alright, got the pins sorted out. tested the voltage on my volt meter on (ACV) I had 26.7v. Does that sound right for a single power supply. Did I have the tester on the wrong settings.
Make sure your charger cna handle that kind of voltage. I know the 306 can, but not sure what charger you are using.
pvolcko
You also said you used ACV setting on your meter. These are DC output supplies. There should be no AC component to the output. Switch to DCV.
redwings
Aw crap Ill change the settings
