Ok all finished
If I can give anyone some advice with building these mini quads, it would be to use a Power distribution board.
The air was think with bad language today, trying to solder all the wires together.
So much easier with a PDB, but I got it done eventually
I replaced all the ESC wires with longer ones to make bundling the wire together more easy.
Then instead of Heat shrink tubing, I use balloons to cover the ESC
Wiring is a bit messy at the moment. I will tidy it up once I know everything is working properly.
Gopro with FPV cable connected
Rear has blue LEDs Looks like a space craft when flying away from me.
All setup and ready. I did take it for a test flight tonight, but it was pitch black, so the video is useless.
With the Open Pilot CC3D set up with some settings I found on Luminiers website for the QAV250, it flies pretty good.
Tomorrow the wind is back, so might not get a chance to fly until Sunday.
Heading to Portugal for a weeks holiday. It will be in my suitcase thats for sure.
With the 1500Mah 35C Zippy compact, I got 7mins on the test flight. Still had 3.74V per cell
