1st post
from the moment i upgraded the cc3d firmware i had trouble with oscillations and wobbling. i also noticed that the ESCs dont beep in a clean sequence anymore at powerup, there is a longer gap between the 3rd and 4th beep. i calibrated the ESCs but that did not solve the wobble.
i reduced the PIDs so low and activated TPS because i still had oscillations on high thrust jumps, but the vehicle got sluggish and my frustration bigger.
i then changed the receiver to a FrSky D8R-XP and use the 8pin PPM protocol and my ESCs set to PPMsync:
SMOOTH AS HELL!!! not a single wobble anymore even with very high pid rates (like double the default).
also the ESC beep in a clean sequence at startup again, so,my guess is that the cc3d firmware upgrade
s up your esc settings. its shown as 50hz pwm, but since my formware did not match my gcs version i doubt the 50hz pwm was the default, because the stock (myrcmart) firmware runs just fine, its just out of date for newer openpilot versions.
