Did you recalibrate the starting point of wach motor in the wizard?
In the setup of the CC3D, did you make sure the quad was completely level before you hit that calibrate button? If not, then you need to do that.
You can go into the cc3d program and click on teh icon on the left that looks like a bubble level. On that page, with your cc3d connected, you can level the quad again without having to go completely through the whole setup.
Click on Input in the cc3d program, then click on the Tx setup wizard. I suspect your sticks are not registering as center. Make sure everything is centered whey they instruct to do so. Make sure you are giving full throws when asked as well.
It's my pleasure. I'm still new to these boards and learning more and more every day.
I dont maybe this hobby is not for me
I flew my quad for morning practice and after 1 minute the quad suddenly goes down as one motor stop working but I found out that ESC was acting weird.
At initialization the ECS (affected one) gives extra beep and when you throttle the ESC beeps as well. I tried the steps below but no luck.
- tx on
- Full throt full
- plug batt to esc - wait 5 secs
- Full throt zero
- dis con batt
- tx off
At initialization the ECS (affected one) beeps properly but when you throttle the ESC beeps. I tried the steps below but no luck.
- tx on
- Full throt full
- Full throt zero
- dis con batt
- tx off
updated!
Have you tried checking the motor/esc through the Vehicle set up wizard?
Try recalibrating them, then go to the motor set up page and test the individual motor/esc combos.
If that works, then at least you know they are working.
If not, try moving the affected ESC to another port on the RX, to test if its an RX issue.
Next try moving the ESC to another motor, to see if the issue follows the ESC, or stays with the motor.
Don't give up. We all have issues at one time or another. I'm having issues with two of my aircraft at the moment![]()
First things first.
You cannot have the bare ESC pressed against the carbon arm.
You are probably shorting out the electronics.
I would say its shorting out the esc, then re initialising.
I would check all your connections. The sound is the esc initialising.
So when you give it power, it may be that its loosing connection somewhere, then restarting.
