#2 servo actually looked like it may have been a little off so I removed it and sure enough it was a couple splines off. I'll remove the other two to check them and adjust as needed.
After some thought on what I have accomplished so far, I think I understand how this setup works. After centering servo arms and setting links to 90, you then connect the swash and adjust the link lengths to level the swash. Then you install the head and start the pitch on the blades.
I need to make sure of something. Do I need to stay in G menu whilst working on the swash? I think I need to exit that menu to do that. Not sure. When using the zip tie, where do I start? at the highest arm? Lowest?
I went back into menu G just for kicks and have found something peculiar. At status led off, the servos are at the center reference position. When I select ch1, the ch2 servo gains a little height until I go back to no status led off. Should I go into ch2 and lower it?
Yes, you stay in G for the swash leveling. As for where to start, that is just a random pick. Just pick one and go from there. And yea, that is a little weird on the ch2...
If you have the servos and swash already setup then definitely put the head on and set the 0 pitch (in G) and then go to the full positive and negative.
