bigone5500
Thanks Geena. I don't know if the AR7200BX has that feature. It is locked up from the factory so you can't use it on another heli. I'll look though.
I’m pretty sure it’s setup menu G.Thanks Geena. I don't know if the AR7200BX has that feature. It is locked up from the factory so you can't use it on another heli. I'll look though.
I found it cracked. Then removed the screw and it just crumbled. I don't know. I have more spare parts than I realized so I'll be working on this tomorrow.How did that happen? did it break in a crash, or when you were taking it off?
Me too. I'll be going over it with a fine toothed comb tomorrow. No telling what else is wrong.I`m glad you found that before it caused a serious problem.
I know the tape you speak of. I have replaced it before. I used 3M tape last time.I go over my helicopters every time I`m finished flying for the day. It`s a good habit to get into, and it can save you a lot of headaches. Now that the contest season is over for a few months, I`m in the middle of replacing all of the ball links, swash balls, and bearings in my contest helicopter. Plus some general maintenance to make sure it`s in top condition for next season.
One thing that you might want to consider changing on your helicopter that to me, gets overlooked a LOT.... is the gyro tape. It degrades over time, and loses its stickiness, that can allow the gyro to move or even come off.......very bad day if that happens. I change the gyro tape at the end of every season.
The 3M is what I use too. You can get it at Walmart for like $4.00 for 4 or 5 feet of it.I know the tape you speak of. I have replaced it before. I used 3M tape last time.
