Gaba, I've been slammed with work lately. I'll try to get it edited and posted tonight. I ordered a set of gears and a new DS615. If the gear set doesn't come with the pin then I'll put the new one in and keep the old for parts.
Xokia, it may have helped once I was past the tree, assuming it indeed still had power. But, yes, bailout or SL prior to the tree would only have made it nice and level as it sliced into the foliage from carried momentum.
That said, I'm almost wishing at this point that I did hit the tree. Nice big pine tree. If I had hit TH in time and it slide into it, the heli might have had a softer go of it and I may have actually been able to attempt a run, jump and catch on the whole thing by the time it was at the ground.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Or it would have blown apart into a thousand pieces since the head speed would have been way higher at that point than where it actually hit the ground.
