I was doing more testing on tail pre-comp settings and ESC settings. I was using my bank selector switch to select between different pre-comp settings. However I left the settings I had on those positions in place too (sport, 3D, crazy 3D). I was at the end of the flight literally on the last manuever before I was going to bring it down. I was finishing testing and had it on the last bank setting, which was most aggressive settings. I have to watch the video to remember what I was doing and what I did wrong, but I think I was doing a semi-stationary roll and it was coming back toward me and a big pine tree so I put a little but of forward elevator into it, but it was inverted at the moment so it did the opposite of intended, quick bit of panic as it was practically overhead and very near the tree coupled with the super aggressive settings, it got out of control and uncomforable quick. Hit throttle hold it drifted by the tree (blades chopped some branches I think) and was floating backwards inverted into my other neighbors yard. I tried to recover it but it didn't spin up and I do not believe I had cyclic control anymore either. Possibly a battery cord snagged on the tree and unplugged? Not sure. Anyway, it went in unpowered, inverted and possibly starting to bank a bit. Left some monster chop marks in my neighbor's yard.
The damage:
main blades, tail blades, main blade bolts, elevator ball link, couple of links, ail control shaft, one set of servo gears, skid pipe, boom, tt, main gear, possibly tail shaft (tested it but hard to tell without being able to spin it up) and a tail boom support (on the heli it seemed to have too much flex, but off it seemed the same as the "good" one).
Was flying without the canopy so no damage to that and luckily didn't damage anything it might have protected. Had to order everything but the boom and main gear. and I just realized I forgot to put the servo gears on my list so need to order them up now.
It was bound to happen at some point. Kind of lucky I did it here and not at the club field. If it were at the club I would have come down hard on someone's vehicle probably. Of course if it were there I wouldn't have had the tree in play, wouldn't have paniced, and likely would not have attempted to correct the backwards drift until completing the maneuver.
Most expensive crash yet. Could have been worse, though.
Question for you guys, re the servo damage. I cracked it open and saw two teeth sheered off a gear. I got those cleaned up and it isn't binding anymore. Hwoever, the pin that acts as an axle for the middle gears bent. I can get a new gear set, but as far as I can tell it does not come with that pin. Is the only way to get that pin to buy a whole new servo? Is it reasonable to try bending it back to something close to straight and roll with it instead of buying a whole new servo?
