Got some more done.
- Ikon setup is complete, I believe. I have not setup auto-level yet.
- ESC connectors are soldered on. Made one goof, forgetting some heat shrink before putting a bullet in the EC5. Going to wrap in some electrical tape. I like having short shrink segments near the connector as a sort of strain relief and to cover up any soldering discoloration or other damage to the wire cladding. Also spliced in the take off lead to power the BEC. Screwed up and made the lead too short so had to cut that and splice in another segment.
- Motor and pinion, mounting block and lower bearing block are LT'd down.
- Tail servo setup done, horn adjusted and link ball reinstalled and backing nut LT'd down.
- Tail blades installed.
Remaining:
- Tail control link guides need to be set.
- Wire routing and zip ties.
- Sat rx's placed/mounted and leads routed.
- Mount the Ikon.
- Get batteries velcrod to plates, and strapped down.
- Recheck everything.
Then... maiden flight.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Stumbling block. Not enough velcro straps. And LHS doesn't have the length needed to secure these batteries. I'll see if I can scrounge up what I need here.
Weather tomorrow is supposed to be very windy, but Sunday or Monday are looking good. Tuesday is looking to be very nice. So Tuesday latest. I recently joined a local RC flight club and heli day is Tuesday so would be good to have it flying by then.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Question on Ikon setup: What cyclic deflection pitch should I set? I'm familiar with collective pitch (set to 12 deg). But not sure what to set cyclic too. For the moment I have it set to 10 deg. Nothing is binding at full extensions.
Remaining:
- Mount the Ikon.
