If your servo arm has been centred with the rudder sub trim at 0. all linkages set to put the tail pitch slider in the middle of the tail shaft, gyro in head hold, then the next thing is to adjust for "tail creep"
Does the tail move slowly over to the one side on its own once you have give a rudder input?
Go into you sub trim for rudder and add opposite trim, checking all the time by moving the rudder stick.
Eventually you will get to a trim point that the rudder will now stop creeping to one side. Give it too much trim and it will start to creep the other way.
Try this and let me know if it helped.
