I did mention it in post #36 and 38 ..... ah well .... you will get it sorted.
take the gyro Gain up to 70 and see where you are..... if it wags ... back it off 3-5 clicks and refly.... in a few hops you will get the tail sorted.
oh and you want to cange the Gyro Direction .... not the Servo Direction ..... unless your blades were not moving in the correct direction with the rudder input itself....
from post #38
[h=2]Re: Trex 450 pro dfc super combo 3gx[/h]
yes.... and when you push the tail ======>>> to the right.... the slider (on the rotor shaft) will move toward the boom... and the blades will g in the same direction as when you push right rudder.
hope that makes sense.
