Todays pictures shows some of the work on the floor and also on the doorframe. As the hinges on the doors are bolted on with tiny brass bolts with a nut on the backside i had to make a cutout in the frame and move it a bit inwards. I used styrene for this job and a little primer would do the final trick.
Did a lot of thinking on how to make the floor. There is quite some space under the floor for electronics or something. So i decided to epoxy 13 x 13 mm wood on each sides of front spar to give more support to the floor. Drilled holes and bolted them on for extra strength.
Used 2 pieces pin-stripe airbrush tape facing the sticky side up and placed them on those woodblocks - its a little stiff so it was easy to manipulate them to be centered on the woodblocks. Then i carefully place the floor on top so the tape would stick to the underside of the floor - this saved me time of measuring and minimizing the risk of making a mistake. So with the tape on the underside of the floor it was easy to measure where to put 4 3mm holes.
I use countersunk stainless 3 mm hex bolts to bolt the floor on. So i put the floor on again and pre-drilled 3 mm holes into the woodblocks. Removed the floor again so i could use a 5 mm drill to make the 4 holes for the threaded bushing inserts. My method of getting exact alignment for the holes worked like a charm. So now i need to find some good material to cover the floor with - something like a rubber mat.
I would also like to make some sort of a raised baseplate for the gyro and receiver maybe also removable, i don't know for sure yet. Still much to consider when it comes to placement of electronics and LiPos.
I would like the covering for the floor to get a few mm up the wall on the inside of the fuselage to hide the little gap between floor and wall.
I hope you all had a nice xmas and i wish you all a happy new year - this was my last post this year. ;0)
And of course a little shot of my workshop tastefully decorated with a little plastic christmas tree and pornlighting - a nice combination.
