KLA
Hey thanks Keith! Never noticed it before.
No problem, Rick. Glad to help out.
Hey guys, after you post if you need to edit there is a box in the bottom right corner of your post that says "Edit Post." It shows up on your post when your post Is actually posted on the board. Just click on the edit post box and it will pull up your post so you can make any changes that are needed. Just be sure to click the "Save Changes" box after you make the necessary changes, which is at the bottom right corner of the edit box.
That is after the delay time. When you first make a post, you will have an edit button just in case you see a mistake within 20 minutes (I think). After that, it goes away. It's a long story with no good ending as to why I have it set this way, but this is the way we have had it for years and I don't see changing it any time soon if ever.
If you need an edit, just post it in a new post and at the very top let me or my staff know you want post #whatever edited with teh below content. Make sure to post all of the post so that we can just go in and copy and paste the info in.
Nah .. dosent work for me .. under Posting Permissions it says "You may not edit your posts".
regards
Wow Sweetfrost, it's looking great!. You diffidently have some patience. That word doesn't even exist in my vocabulary, Lol. How many man hours have you put in so far? Good luck with the rest of the build. Keep up the good work![]()
That thing is turning out really nice! Are you planning on entering it into any of the shows?
Can't wait to,seem they assembled and in the air
Short update again. Drilled holes for 2 mm hex button-head bolts in the landing-light housing and made a testfit on the fuse - priming it tomorrow. And today i gave the batterybox the final painting. The motorblock, metalframe and the batterybox is going to be painted in gossy "Stoneleigh Grey". Pictures coming when all is painted and fittet to the main frame.
The hole above the lights is air intake for the cabin. There is a steeltubing all the way up on the inside of the window spar and its visible at this hole. I already made the entire box with air-vents i post pictures on this later also.
Those drip rails came out very nice! Are you going to do any details of the engine looking thingy?
Yeah your right, really couldn't do much with it, it would start looking kinda weird to try and detail that up.....sweet on the fuse pix can't wait!
