Sweetfrost
Working on the battery-box that sits on the left side frame. The picture shows how the heatshield is mounted - in real its close to the exhaust tubes and need this shield. 2 short pieces of the piano wire (one each side) is making it out for a rod with threading in the ends to secure the lid. And the little square on top is where the + and - signs placed with the 12V indication. I had a problem finding some very small wing nuts so i had to try to make some myself. Used hard plastic tubing and styrene and also a M2 nut to make them - not the prettiest wing nuts but it will do. One its all painted and mounted on the frame it will look okay.
