Wow, no responses from anyone on this. Guess this thread is losing it's interest.
Well guess what, I think I'm FINALLY finished with the sump. When I got off work friday morning, I headed straight to Lowes and picked up all of the fittings and pipe that I needed to finish the sump install. $70 later, I walked out of there lol. The plan was to just come home, go to bed and wake up early and get started on it. That was the plan...
Once I got home, I started laying things out on the table like I wanted them on teh sump. I was seeing that I didn't have what I needed. I know I double and triple checked everything before putting it in the cart. Ah well, keep fitting. About an hour later, I had the whole layout done and I knew exactly how it was going to go together. Let me tell you, even as big as it is down under the tank, I was running out of room fast for this plumbing. But I kept on.
Finally, I made the decision that I would just start on it and get it going. This was at about 0800. I usually go to sleep at 0900. I started with the drain from the tank into the sump. Simple, come down, 90 into a T that drops into the sump, goes over to the other inlet to the sump, 90 and down. Need to put a Union in there, that was a bit tricky but got it done.
Okay, the drain is done, now for the return. Let me tell you, this was a pain in teh butt to get done. It had to come up from the pump, over to the refugium then over to the tank to return to the outlet. It took me a good hour to lay all of this out and get it all glued up. But, I got it done. Things here are cut to within 1/16" of an inch. But, it was done.
The Tru-Union valve that is on the refugium was supposed to be on the main pump, but I picked up the wrong valve so had to swap them around at the last minute. Not a big deal, just wish it would have went different. Anyway, below are the pics of what I have going on with the sump at the time I FINALLY went to bed at 1300. Yeah, that late lmao.
Here is a shot of the whole stand just after instillation.
Here is a shot of the return back to the tank. As you can see, there is a bit going on here.
Here is a shot of the drain into the sump as well as the return to the tank.
Here you can see that the water is not near as turbulant as it was in the last pics.
This picture is just showing the water movement going from chamber #1 to chamber #2.
Here is another angle on the return plumbing. As you can see, it comes up from the pump into a 90, over to a corner 90 that drops down to a valve to regulate the refugium, then goes through a one way check valve, through a union to take it all apart then finally up into the tank.
I ended up stirring up a LOT of crap in the tank. The fish were just waking up and they were pissed lmao. Center left you can see my temp probe that I moved from the sump since I had no water flow through there. Center right on teh front glass is the heater, again for teh same reason.
If you mix the salt to what the manufacturer suggests, you will get a specific gravity of about 1.021. Well the corals that I keep want more salt than that. So, I'm running between 1.025-1.026. And the corals LOVE it.
fast forward to when I woke up at 1900, and I got started on it again. This time, it was installing the light, skimmer, fan, heater, probes, sand, macro, rocks and finally getting the refugium running. I had to mix up some new saltwater though. The sump is so big that I ran out of my supply while trying to fill it. I was about 10 gallons short. For those that don't remember, or have not read the whole thread, the sump will hold just over 40 gallons by it's self when full. Normal running, I'm at about 25-30 gallons.
Here are some pictures after I finished everything.
Again, here is a full stand shot with everything in the sump
Here is a shot of the return pump with the heater. The heater was placed to allow the heated water to immediately go into the tank and be more efficient.
Here is a shot of the left side. The skimmer for some reason ws not skimming like it should be, but as of the time of this post, it's doing what it's supposed to.
Here is another shot of the right side. You can see the refugium light that helps the Macro Algae grow as well as the fan that kicks on at 83ºF. You would be surprised at just how fast this fan cools the tank down.
Here is another shot of the inflow to the sump and the filter socks. Just because lol. I still can't believe at just how well this system works. And I designed it.
Here is a shot of the tubing that comes from the tank to the sump. This allows me to see if there is air in it. No air means I'm about to over flow the tank. As you can see by the white, there is plenty of air. It helps that I have the pump choked off a bit lol. It's a BIG pump.
Here is an upclose look at the heater. As you can see, 300 watts and working it's butt off to heat this tank up after being shut down for a few hours. However, I noticed a problem. Just below the label, you see some condensation. This is BAD! That is why I now have the top fo the heater out of the water. Just in case there is an electricity bleed.
This is the outflow from Chamber #3, the Refugium going back into Chamber #1. As you can see, it's not flowing that fast at all, and I have reduced it even more.
This shot shows some of the sand and rock of the refugium. I decided to go with about 2" of sand. The green rocks are out of the main display and the white rocks are out of a bucket that has been sitting outside for about 4 months. I will be adding more as the white rock cures.
This is the pipe that is supplying water into the Refugium. What is hard to see is it's sitting in a clear glass to force the water and bubbles back up. If you look close, you can see the bubbles at the bottom of the pipe, as well as one bubble that was rising just to the left of the pump. This keeps the sand and Macro Algae from being blown around. And, another piece of rock from the tank.
Here is a shot of the Chaeto Macro Algae. This is what helps suck out Nitrates and Phosphates from the water. Both of which are VERY BAD for fish and coral.
Here is a larger shot of the refugium. However, because water bends light, it looks more empty than it is. It's almost up to the lip that the black cased light is sitting on, by design.
Here is another shot of the Refugium. There is going to be all kinds of little critters in here very soon. I'm sure they are in there now, they were just hiding.
So that is where the tank sits as of now. I did get the new pH probe in and replaced it. Both Neptune Systems and I thought it was a probe issue causing the pH to rise when I plugged in my VDM and turned the lights on in the tank. After WEEKS of emailing, I was at the end of my rope. Paul, the support tech for Neptune, did everything he could to try and figure this issue out. So, frustrated with the friggin thing, I figured I had to have some kind of electricity bleed in the tank. Yes, the first thing I unplugged was the heater. No change.
So, I unplugged the skimmer, main pump, refugium light, stand light, power heads (one at a time) and nothing worked. Then I started to reach to the power strip to unplug the LED drivers one by one that power my main lights. That's when it hit me... Maybe it's with the power strip...?
I pulled the plug from the power strip out of the power bar on the Apex system and that is when I saw it. The ground pin on the plug was broken off. this resulted in no ground. And with something like these drivers that convert energy, you really need a grounding pin.
So I unplugged the drivers out of the power strip and plugged them into their own plug on the power bar. BOOM! Not a single change in pH. That was the answer all along. I sent Paul another email explaining what went on and what I found hoping that it would help both of us later on.
So now, the tank is on autopilot. Right? Yeah right lmao. I will find something else to do to it here soon lmao.
Now that all of that is done though, I can FINALLY get started on my Nano project. I can't wait!
