It has been 7 days since my last post when I dosed my tank. And yes, I do have video but the ending is not the best it could have been. However, I took an even more drastic approach than I thought I would have to. The first dose that you see above is what is suggested and it is what I put in the tank. 48 hours later and it didn't look like I had dosed anything. The tank was exactly as it was before dosing. You are supposed to do a 20% water change (20 gallons for me) and then dose again. Um no, since it didn't even touch it, I just dosed it again! What's the worse than can happen... So I dosed it and I waited another 48 hours.
After this run, the algae was still red in some places, but other places it started turning grey. This chemical oxidizes the algae which is why it drops your pH and the grey algae is oxidized algae. Okay, but I still had algae. I do have enough for a third dose but quite honestly I think two is taxing enough on the tank so I decided to not do the third dose. Instead, it was time for a 30 gallon water change. I already had the water mixed up, I just needed to do it. However, I still had algae, so I decided to use this time to siphon out the algae. But even more so, the really bad rocks I'm taking out of the tank and leaving in a dark area for about a week before I put them back in the tank. This will keep the bacteria in the rock alive, but kill the algae since it doesn't have any light. So I started pulling out rock.
Of course little s**thead (male clownfish) was biting the crap out of me so I netted his ass and put him in a little cup of water while I worked in the tank. He's fine, don't worry. I started pulling out rock, siphoning rock and I even went as far as to siphon the sand with a gravel cleaner. You have to be careful doing this as you can suck up sand, but it takes the detritus out of the tank. With that done, I put some of the rock back in the tank but left the two worst ones out as stated above.
I drained the water level way down and kept some in buckets just in case I needed more than I had on hand. And I did lol. I stuck the tube from the barrel into the tank and started filling it up. Since I had multiple corals out of the water I used the hose to soak them down so they would not dry out. And yes, they are fine. Great, tank is filled now it's time to put my skimmer back online. As you saw in the pictures above, the skimmer was producing a foam that would cover the sump with a thick layer. This is because the chemiclean makes the water so cohesive that it can make bubbles quite easily. And the skimmer is made to make bubbles. It's what it does lol. So I knew I would have an issue with overflowing.
In this picture you will see my solution to the overflowing skimmer. When I did this, I had the skimmer pump set to 1 out of 8 so it was on the lowest setting I could put it on. Also, just to the right of the skimmer cup, you can see a red tube. Attached to the other end of that tube is the valve that regulates how high the water level is in the skimmer. I had it removed and had the pump on the lowest setting and was still overflowing! And yes, I knew it would, it's just what you deal with in times like this. So my solution is to, for the first time since i have owned this skimmer, remove the plug from the drain and run a hose into a 5 gallon bucket which is what you see in the picture.
Yes, the hose is WAY longer than it needed to be, but if I would have run it straight over the side it kinked rendering it useless. And I didn't want to cut this hose since this is what I use to siphon out sand from my tank every now and then. And speaking of that, I found out that my sand is about 5" thick in the back of my tank lol. That is way too thick! so I will be doing some more work with this hose lol. But, I was going to bed at this time hence such a large container.
Next day and it didn't overflow as much as I thought it would which is a good thing. So I plugged the skimmer cup, put the valve back on and started dialing it in. Today it is working great and doing what it should once again. So the skimmer is back where it needs to be.
My Nitrates on the other hand are still high so I want to do another large water change but as you can see in this picture, my DI resin (far left) is about used up (blue is good, gold or orange is bad or consumed). The other filters are sediment, carbon and RO membranes.
Well, I needed to make a full barrel of RO/DI water and with that little bit of DI resin there was no way I was going to get a full barrel, or even half for that matter. SO..... It was time to break out my new toy
My wife called me a geek over this system lmao. Let me do some explaining that most will not understand and could probably care less about. In the first picture of the filters, that DI resin is a mixed bed resin with both Cation and Anion particles. Since it is blue, the Anion is what is dyed in that mixed bed. So as it was making clean pure water, it was showing the Anion being used up. But, you have absolutely no way of knowing if you were using any Cation since it was not dyed. Well in the picture above, the far right canister is again a mixed bed resin, but this time it's the Cation that is dyed. This is what they call their "Pro Mixed Bed Resin". So in this one, I can see the Cation depletion but I can't see the Anion.
Okay, but why....? Well the other two cartridges are exactly the same as the mixed beds, but they have not been mixed and they are both dyed. On the left is an absolutely awesome looking purple Cation resin and in the middle is a very vibrant blue Anion resin. With most water, you will use the center Anion the most. From what I have been told you will go through about 4 of the Anion cartridges for every 1 of the Cation. And for every 1 of the mixed bed resin on the right, you will go through about 4 of the Cation's. So I will pretty much only have to replace the center cartridge.
But why? I know and I'm getting there. It's all about saving money in the long run. I didn't get LED lights because I like them, they save energy. But I had to spend a grand to get them. But, they have paid for themselves over the price of metal halide or even T5HO's. The DC pumps I have replaced (main pump, power heads and now skimmer pump) were all to reduce overall costs of running this tank. And again, they are actively paying themselves off. I think the main pump has already done that. Same goes with this DI resin. Since I'm only having to replace the Anion every now and then, and the other two very rarely, I save on resin. And since it is not mixed, it is cheaper than the mixed and I'm not tossing away unused resin that is still good. So in the long run, this will pay for itself. It's going to take a while though, this setup was not cheap lol.
So that is where I sit now. Like I mentioned I do have video of this process as well as some video I sent Matt while I was doing it. If you want to see it, I will see about getting it put together and making that happen. Just let me know. As for now, I'm going to keep enjoying my clean tank. Well, other than the brown algae, but everyone is going to get that when they don't have enough critters to keep the sand moving around. I'm working on that. Now it's time to go check on my barrel of water and see how it is doing...
