Marius' learning to fly - "video diary"
stokke
Thanks, You'll be over taking me soon if i don't get my heli back in the air. Went to the shop yesterday, no landing gear :( guess i'll be in my friends workshop tomorrow making some DIY ones. :)
LOL, post some pics of it when you're finished!
stokke
Was at the cabin this weekend, riding my snowmobile, chillin and flyin :D
But. I have been trying to find the best gain on my GOV for the 600, I was at value 30 (which was working out nicely last weekend) - so I tried upping it to 31. So on Saturday I took her out for the first test at value 31 - the motor started hunting... This also caused the tail to twitch as a reaction to the motor not flattening out it's head speed. I did two flights anyways - and all seemed fine.
Today I reduced the gain back to 30 again. The motor was still hunting (not as bad, but still). I did one flight - worked fine (and I got some awesome tic tocs :D ) Then, on my second flight, I tried the tic tocs again - then this happened:
I should obviously not have flown with it knowing that the motor was hunting - but I'm stupid, so I did it anyways. After studying the damage, I can also see that my mesh probably was a bit on the wide side.
New main gear on the way - new test flight next weekend.
breeze400
Spagetti Pilot
Defiantly looks like it wasn't lined up right. Best thing to do is find the hi stop in the gear and set up your gap there at the high spot. Then it should no ok.
At least you got it down in one piece. Now are you sure it was the main gear causing it to sound like it was hunting? Is it possible that the motor slipped thus mucking up you mesh?
coolgabsi
Super Mod & DEAL KING!
Looks like a mesh problem to me too.
I have had a bad experience like that with both 450 and 600..
And yes.. How did you get it down?
Fly safe!! :) have fun!
If the gear mesh was out a little, it was a very little. It took almost all of the teeth off down to the solid gear meaning it was pretty tight.
Hope that is the only damage.
stokke
Two times I've stripped gears on the JR, once on the tail case, once the main gear. Both times the machine continued to fly - but letting me know something was wrong by emitting horrible sounds :D Nothing else took damage :D
As I see it, three factors contributed to the gear strip; GOV and motor hunting, Mesh not tight enough, over powered vehicle.
Re: Marius' learning to fly - "video diary"
Listening to your last video again Marius, I can here a strange warbling sound coming from the gears. May be this has something to do with it, or not. Maybe its a normal sound for this bird, but its whirring noise that tells me something is out of wack. If everything is aligned and balanced the sound should be a constant whir not a fluttering noise like i can hear. Listen again and tell me if you think you hear it too.
stokke
I know EXACTLY what you mean. I always thought it was the motors "unique" sound. Remember, it's a low cost Turnigy motor - therefore I thought it's normal. But since you are pointing it out, maybe something is "outa whack"...
When talking about oddities; the main gear (the one I stripped) was NOT perfectly circular. I found this when checking for mesh the first couple of times - but chose to look past this, as I know for a fact that most gears are never PERFECTLY circular. Hmmm.
When the new gear arrives, I'll have a thorough check on things. Thanks Lee.
If the new gear is out of wack, just make sure to set the gear mesh at the tight point of the gear.
Have you measured the HS? What TH curve are you running?
stokke
I have not measured the HS with a tach - no. The GOV is set at 2300 HS.
coolgabsi
Do this Marius, email a jr rep or just horizon hobby and ask them about your power plant. In my option your power plant is good and not "overpowered"... Lets see what they say. Can't hurt and at least we will know what's the deal
Gear mesh .. Yes will cause this.
Governor hunting shouldn't cause this... At least I can't think of how it can at the moment... But I don't know everything either lol :D
stokke
Yes, I want to blame the gear mesh also. I see the new main gear that's coming, is not like the one I got. The new one is made from a white type of un-polished plastic instead of the black polished I've got now.
The reason I thought RPM hunting may have caused this, is because the motor was jerking quite a lot - I'd imagine this puts a lot of strain on the entire drive train for a short moment. This combined with some serious collective pitch change may put some serious torque on the gears for a short moment. If you can understand what I'm getting at?
coolgabsi
Yeah might be.. That sounds like a possibility.
I know on my 700 the stock align white gear has stripped on people with a 5.2kw setup of higher ... (I am at 5.2kw at this moment) .. So I know over power is a possibility.
Good thing is align just came out with a black RIGID main gear. Like y'all saw those tail torque tube gears, just like that there is a main gear now too that takes care of that stripping issue. So I have black tail gears and black main gear ...
Point is now I see that jerking could look like overpower too after you put it that way :)
Ask jr .. :)
2300 is very high for a 600 size heli unless you are doing smack 3D. I would drop it to 2100. I have my 600 set to 1900, 2100 and 2200. In general the 2100 is fine for my flying and it gives me a couple more mins flying.
stokke
The JR manual states 2200-2400 for Sports/3D flying. Besides - i love flying with that HS :D
If it helps prevent stripping more gears, I might drop to 2200
breeze400
Spagetti Pilot
Pretty much from what I've read, Most main gears are not perfect. Thats wht you have to find the high spot on the gear. Set your mesh there. At least thats whay I've been told. I haven"t A clue has to how it stripped though. Has Tony said looks like the entire gear stripped out on you. Maybe simple thing has A bad gear from the factory?
stokke
Who knows? Not me :D I'll see what happens to the new one - if that one gets stripped as well, I'll know for sure I have have an issue on my hands.
