OH ouch that 450 hit hard! how bad is the damage? didn't sound like you hit TH before it hit.
sorry that happened but you will have it good as new again. And that Goblin is a rocket!
Damage report at the bottom. Thanks Jeff!
It looked like you powered it in. Did you lose orientation?
I should know nose in inverted, it's my "fail safe" inverted position. Typical brain fade moment
LOL
oof. I haven't done the inverted direct plow into the ground yet. My inverted crash I managed to get it half flipped right side up before it went in at damn near full negative pitch.
What's the damage?
Yeah, it's quite a stupid crash LOL
Damn bro, ouch, that sucks. Hope the damage is not as bad as it sounded!
Sadly it was a bit costly. That's the hobby for ya
Thanks Tony
Man what happened Marius you were doing so well till then. Did some thing come apart on the heli to cause the crash?
Nah, I can't blame nothing but myself for this one. My brain simply took a break hahaha
Thanks Sam
Ouch!!! That measured on the Richter scale. Wrong pitch input, or mechanical? I did that the other day but caught it about 2 inches from the ground.
The Goblin was looking sweet. Super fast turns.
Positive input instead of negative. Brain fade moment. Thanks Lee
___
Crash report: tail boom, swash drivers, servos (again LOL), main blades, main shaft, feathering shaft (probably), main gear. I'm going to use this opportunity to take out the AR8000 and bind only to the 3GX with Sat.
Thanks for your comments
