stokke
Amazing bro, simply amazing. I don't know if you noticed or not, but when you were in IU, the heli looked much more stable than in normal mode.
As for the pitch settings, your swash is too low. You said you shortened the links 2 turns. Try to lengthen them one turn and see if you can get any closer. If not, it's not a big deal. Keep it up, you are doing great.![]()
Thanks, Tony
At first, I was sort of afraid of the IU mode
As for the pitch, I feel she's flying so good now, so I will postpone adjusting this. At least for now.
You make this look easy great job man keep them coming. Work on some nose in hovering and soon before you know it inverted.
Thanks, Adam!
Will work some more on the nose in. It's just that I'm nervous doing stuff in IU, which i could do easily in Normal mode before. Guess it'll pass eventually. Inverted is my next goal, but I cannot rush it - need more time with the Sim first.
looking good. did you have to recenter all the trims since you leveled the swash?
Thanks, Matthias.
I re-did everything. Took out all sub trim, then adjusting until 90. Then I adjusted the swash links individually until the swash was level. My lesson has been; "One cannot rush while setting up the head". LOL
Great flying man!
Thanks, Sam
Today, we're blessed with some good weather again!
Also, I went ahead and ordered another battery, so now I have three packs
Seeing that I have so "many" packs now, I have decided to only record my last (third) flight.
I've been working on using Idle Up. I expected that this will drain my batteries faster, but I had a bit of a doozy on my second flight. Just as my alarm goes off, I am still in IU, and THEN she's starting to loose power! I tried to land on my ramp, but had to abort - she was running out of juice FAST.
This resulted in an emergency landing in the field...
After removing all the grass from my tail rotor, I lowered my timer quite a bit.
Turns out, when flying in IU compared to Normal mode, this shaves off about two minutes of flight time...
Well, here's my latest flight.
http://youtu.be/JqKZjqlUNBI
MAN, I'm having a blast flying in IU Mode.
It was fun flying in Normal as well, but it's just crazy how good it feels to mess about in IU
After these last runs, I also noted I'll have to increase the tail gain, as it keeps slipping in IU.
So now, I'll also have to learn to switch between NORM gain, and IU gain. But it's just a matter of practice.
I would just like to thank everybody for your insights and suggestions
Especially Tony, as I feel he sort of "pushed" me into going into IU mode.
