Re: By biggest endeavor yet!
2400 is a little high, 2250 is the max that you want to shoot for. Just lower your pinion tooth by 1 and you will be fine. Remember, this is at 100% throttle which you won't be in all the time. You can always set your throttle curve just a little lower to keep the motor from spinning up to 100% thus lowering your head speed.
