It's all good. Nothing wrong with a little chuckle here and thereI was joking
Ok everything is set right, but what do you mean, power cycle the beast?Well, that's a head scratcher.... Only thing I could think of is if you added dual rate and expo while the control style was set to one of the presets, the controller can see this as stick inputs. Check the monitor screen on the transmitter and be sure everything moves as it should there, and servo travel is set to 100+100-. Of course, be sure the swash type is set to "1 servo normal". Then power cycle the microbeast and see. You may have to go back though it to be safe. Thats strange for sure.
T
Turn off and then turn back on ...Ok everything is set right, but what do you mean, power cycle the beast?
Yup my thoughts exactly. I somehow messed up the setup. Sounds like Rob, ha!Right, just turn it off and then back on after a minute or two. Youve probably already done that. Hard to say without actually seeing it but it's like something you did the controller didn't like and corrupted the setup. If you can't get it back its easy enough to just re-do the whole setup. Not wroth losing the heli IMO. Just the basic setup I mean.
Yup gotcha, going good..............Factory reset shouldn't erase your receiver settings but will erase your parameter settings.
I agree with Fran. Just like humans...we need a reboot every once in a while, lol.Honestly, probably the best thing to do is just redo the whole thing. Doesn’t take very long.
