Control style should be blue and correct on dialing the expo. Yes, there will be some différance in FBL vs FB, so it's not you. You will also have a different feel from flying simulator vs real flight. Just take your time and get the feel of it...it will come to you. Good luck and keep us posted.Hi guys, while i'm waiting on parts. I've formulated a theory as to what caused the (cato), catastrophe at take off...........
I think after some simulated takeoffs with my simulator, the control style (purple), on the Beast is still to sensitive. And during spool-up, if any control input is needed, watch out! Next time around I think I should set the control style to solid blue, (tx mode).. Then dial in around 35 to 40% EXPO in the TX. Your thoughts on this theory...
Do you guys know what I mean about taking off with a flybarless system, right? It's a different feel than a fly bared system. Or is it just me? Tell me, I can take it..
Yes, yes!! this was very helpful..Well, the swash should be level when the helicopter spools up. Checking flight controls before spooling up is fine. BE SURE the swash is trying to stay level when tilting the helicopter by hand. (Correcting in the right directions). Look at it this way, if you give a cyclic command while on the ground the controller can't tilt the helicopter so it will keep trying until it gets light enough on the skids and then tip over. And again, zero sub trim, 100% travel while in any preset control style. This link took me 20 minutes to find but found it. Been a minute since I read it. Some good stuff for you to read regarding tilting over. #6. Hope it helps.
Flying and controlling the model - BEASTX Wiki
wiki.beastx.com
No offence at all. And what's wrong with my Haiku style training gear? Let me have the truth, my teacher, I can handle it. lol......I hope you don't get offended but please tell me that NOT your training wheels? Your asking for trouble.
You know, I thought about that, but thought, I'll add them if anyone says I better. And sure enough, I'd better modify this setup or maybe just maybe buy a set. Hummm....Maybe you should have some wiffle balls on the ends? The points can catch the ground. Makes for a bad day
Ping pong balls work well too.Maybe you should have some wiffle balls on the ends? The points can catch the ground. Makes for a bad day
Also instead of a tic tac toe style training wheels you should try an X style. Just a thought.You know, I thought about that, but thought, I'll add them if anyone says I better. And sure enough, I'd better modify this setup or maybe just maybe buy a set. Hummm....
My self I made mine with metal coat hangar, if you can find them, with ping pong balls at the end.
Ok, awesome, I'm working it now....Ping pong balls work well too.
Each rod is about 13.5" . You need 4 if you go with the X pattern.Hey guys, how long should I make the rods for a 500 size heli?
