Rob Lancaster
Good video Tony. That clears the air. easy...BTW Rob, I remember that Tony made a video. It's 13yrs old, but it's worth watching
I believe my problem is with these settings.
Thanks guys...
Yes they are, those two crashes took their toll on those babies but I think I can get her fly'n good again. The last crash bent the swash plate.. I was very surprised the feathering shaft wasn't bent..Certainly sounds possible. These Align servos for me at least are usually pretty tough.
Hey now, that sounds like a good idea...Maybe run it without the blades when you're ready and look for the swash to stay level.
Last night it was moving smooth by hand. But today its feels gritty again. It's the #1 elevator servo. Note this is the one that bent the swashplate. Or is it Vis versa... Could the motors pinion be damaged?With no power to the servo and if you try to move it by hand, does it feel smooth then? Is it the elevator servo that vibrates or one of the aileron servos?
Oh wow, I don't think so but it can happen. As for gritty, try some electrical cleaner and see if the gritty disappear just myCould the motors pinion be damaged?
Ok, I will do that. I have just the stuff.Oh wow, I don't think so but it can happen. As for gritty, try some electrical cleaner and see if the gritty disappear just my![]()
Is the Futaba stuff more of a light grease or a tacky oil?I use the Futaba stuff, takes very little tho...
I knew dat, I was just checking'n .........Ha! >>>> Nah, nah, just joking..You would NOT use sub trim. After you pick your Rudder servo center pulse, I believe is 1520? At that point you put your servo horn on as close to 90 as you can get. Then your servo end points are set. In a perfect world you would adjust the rudder control rod so that the tail slider is centered. Most fly in heading hold these days so the mechanical setup doesn't matter as much anymore. I still fly in rate mode, so I have to get the mechanical setup right. It's in the manual.
