Got the digital Tail servo installed today. I am now a believer in better servos. I can't believe how quiet and fast the ES09D is compared to the T-Pros. It is night and day. So I think I will order some better servos to use pretty soon.
Question about servo heat. I hooked up the battery to center the new servo had the radio on for a couple of minutes, ran all the servos around a little bit for the grandson to see and when I was done they were all pretty warm. What is normal for servo temps. Do they get warm at idle just from holding everything in place. I Also noticed the Analog servos were way warmer than the digital one.
THanks
Woody
If you banging the sticks during pre flight then they will get warm. If your being easy on them they shouldn't get warm.
Gyro is here, had a really busy weekend so no time to set the rest up. But will be working on it this week. Hopefully test hovering before the next weekend. So much to do so little time. LOL
Murakar, I don't think I was banging on the sticks but it is a possibility. While I am setting up this week I will be going over every aspect of servo travel, endpoints etc. to make sure I am not overdriving anything or hitting physical limits as well. So we will see what happens.
Congrats on that buy Chrisrock. Sounds pretty good. Just make sure you check over everything and take your time building and you should be ok. Listen, learn and re-listen before trying anything is what I do.
Rotary174, I have caught myself looking at the MCPx as a smaller cp heli to play with. Just haven't found an affordable one yet. The higher heads speed is a little scary compared to my v911 etc. but I need something to fly in the warehouse in the winter that is not fixed pitch.
Woody
