Well, I'm thinking that I just have to double check the settings of the Castle 80HV ESC and the Castle BEC Pro.
Checking the esc should be very similar, i think, to what I did to the Castle 50 for my Trex 450.
The Castle BEC Pro is new to me. I see in the specs that the voltage range is 4.8 volts to 12.5 volts. I have the DS615m cyclic servos and the DS655 tail servo and I'm using a 2S 6.6v LiFe rx pack. Since the voltage on the rx pack is 6.6v, can I set the BEC Pro to 6.0 volts or should I be looking at a lower setting?
