Ok...i have an awesome report...
My headache is gone and the crisis has been averted. In typical "Derek" fashion, I was over-thinking things....again. I stepped away from the helicopter and just fired up the simulator for a bit. I came back to the 600 and re-checked things.
At mid stick, I was at +7.3. At high stick, blade 1 was 19.3 and blade 2 was at +19.1. At low stick, blade 1 was at -3.9 and blade 2 was at -3.9. I started to shorten the linkage rods, 3 turns at a time, each. Long story short (we're gonna speed to the end of the story), I now have 0 at mid stick and I am +/- 12 degrees (give or take 0.1 degrees) on both blades. FINALLY!!!
Excuse me while I dance a bit
I proceeded to get the throttle end points set...done.
Double checked all my settings in the Ikon...done.
Set Level for the self level feature on the Ikon...done.
Now, I have some batteries on the charger and I just need to go over a few spots and add a bit of locktite and this helicopter can be considered "Done!".
I spoke with Lee, last week or the week before, and he said that he ran a full battery through his Goblin, on the ground, and then checked all bolts, linkages, etc. I'm going to do the same. After that battery run, I'll double check all bolts, linkages, etc, and then we'll see about a maiden hover in the real near future.
***sigh of relief***
***and another sigh of relief***
