Well, been playing with it and running back and forth to mod the setup. Still no joy. I know the early models of the AR636 had issues with the Heading hold, usually it locked in at the wrong time. In this case it seems to be locking out. It will be sitting fine and all of a sudden spin. And not just slowly either, it was just like I'd slammed the "rudder" over.
No damage, no tip overs, but it got exciting all of a sudden.
Something I did find was where I had used Sub Trim in the Rx for the Rudder Servo, it didn't like it at all, once I zeroed it out and made adjustment to the pushrod to reset it cured some of the movement. What goes afoul is the slight offset of the arm giving differential movement, a possible culprit of the Tail chasing. The heading hold I suspect doesn't like it. Maybe I'm wrong and it doesn't care, but I think there's more to it.
I did read about there addition of the lower Aluminum case and a fellow that had made his own. It's supposed to be vibration cancelling as well and the foam tape mounting. So It could be an issue in that regard.
The whole point of the exercise was to be able to utilize the AR636 units and take advantage of the stabilization features and heading hold making it a cheap intro to Heli when stuck in someone's old dust collector that was purchased cheap. So far, I'm sure they'd toss it in the corner by now and have given up or at least just zero all the features making it a standard Rx and add a gyro. Easy for me to do since I have those parts around, as well as the Flybar parts to put it back as it was.
The Rx programming would require the USB cable or the Bluetooth to Zero it out though and it's added cost for a one time use.
I'll probably play with it some more, but unless I can come up with a groundbreaking solution, the AR's I have can go back to collecting dust. I didn't like them in my planes is why they ended up in the box in the first place.
I had really hoped the $160 spent on those two new would have found a good home.
