LooseNut
Totally agree with the more parts and complications getting them set up, that's why I started playing with it as an FBL, shooting for simplicity for a beginner.
The problem I ran into with the B400 is the Swash is a smaller diameter so a little throw goes a long way.
With the stock setup I was getting +16.03 and -16.04, so I reduced the Swash percentages, Ail +42/Ele +42/Pitch -42.
That backed the Pitch off to +12.24/-12.25.
I can reduce the Pitch further by reducing the percentages, but I have a feeling that it is just making it worse. Reducing the percentage reduces the resolution as well as the travel and it was pretty noticeable rocking the heli on the bench and watching the stability reaction. For that reason I started with the gains at 60% and then slowly reduced them to get rid of the shakes. 45% gains for Roll and Ele had it pretty stable, however it seemed to lag behind and let you get into a PIO trying to hold it level. Big no-no for a beginner and I was barely keeping up with corrections with the wind gusts. For the record, Heading gain is at 100%, not shake or wobble, but will drift slowly with the cross wind gusts. Head winds held pretty tight.
For a gut check I took my little B 230s out just to see how much difference there was. Not quite Apples to Apples, just something to get a reading on.
