Excellent!............That looks much better,
That's what I'm talking aboutHey guy's, will this satisfy the NTSB now?
Still wait'n on parts.
Indeed I have a good crew. Yes, an offer like no other. Thanks but I love the build part and I want to figure out (with your guys help) what the control problem is. That is, now that I've had time to mellow out. I have the Beast set to normal control style (purple LED). There are no other Expos in the radio. I believe the two times I flew it, there were expo setting in the radio. With just the purple setting, it's way to crack stick for me.If you're willing to get it to me I will set it up, fly it and send it back. I know it's not really an option but throwing it out there. Let us know the damage report...
Glad to hear that. As for the servo, becareful on the notchiness. Could be sign of them going. The gears might look fine but a hairline crack on one tooth can be dangerous.Thanks but I love the build part and I want to figure out (with your guys help) what the control problem is.
Aren't there replacement gears available? I know I saw them somewhere. If I can find them, I'd rather replace all of them just to be on the safe side..Glad to hear that. As for the servo, becareful on the notchiness. Could be sign of them going. The gears might look fine but a hairline crack on one tooth can be dangerous.
Order back up for the back-up. When I can afford it, I order double of parts. I always try to have 2 of everything...when I can.I'd rather replace all of them just to be on the safe side
And there they are... Awesome! Order up!Yes, the gears are available. Are yours the DS530 servo? HSP53002 part#. As mentioned before. I would not add any expo or reduced rates in any preset control style. All sub trim OFF. Just set it to "transmitter" then you can add expo and reduce the rates.
T
That's what my microbeast and AR 7200 & 7300BX are set on blue TX mode.Ok, so I going to reset the beast to (BLUE) TX mode.
Sounds good!That's what my microbeast and AR 7200 & 7300BX are set on blue TX mode.
Ok that's one vote no...Just me, but I wouldn't take a brand-new servo apart just for an aluminum top. Just my 2 cents....
Dog, what would be a good expo setting using the TX for the Trex 500XT? Just a ballpark setting should be good. Maybe close to my 450?Sounds good!
One more little thing.
Is it ok to buy a servo with a plastic top case and then switch it with with the original metal top case? Or would that be unethical??
I agree, and I would go far enough to say purchase a new one...two...three if you can.Just me, but I wouldn't take a brand-new servo apart just for an aluminum top. Just my 2 cents....
I have mine expo as linear: "Straight line/no expo" but that just me.Dog, what would be a good expo setting using the TX for the Trex 500XT? Just a ballpark setting should be good. Maybe close to my 450?
