If I go lower then I get more - pitch an less +.
I just have to ask..are your subtrims set to "0" and your servo arms at 90º? For me i always set my swash mix at 60% and work the mechanics from there that way you can add or reduce the mix to get your - and + pitch it will take some time and adjusting and adusting before you get it all set up.
Servo arms were set as close to 90 then added subtrim so they are right on 90. my swash is at 60%. Haven't tried to use swash mix. Thanks..
