Hi Harford, I'll try not to get in too deep and ramble. I'm interested to read Steve's comments on what I'm about to share with you. It wasn't until I joined the Forum and benefited from Steve's insight that my own understanding picked up a league or two.
With my change to FBL as the tech side raced ahead of my available time to spend learning the hobby, I too have pursued mastering the mysteries inside the little box riding on my helis. Although I knew a few extremely good flyers none of them could satisfy my thirst for knowledge. I quickly realised that they just didn't know the answers or didn't know how to explain it to me. So here goes.......
The FBL systems take over almost everything that was done in the transmitters and when making the transition it's very easy to introduce conflict between the two elements of the control system. At the moment, I've only accumulated just over 20 hours of what I call useful flight time so I'm not able to push the gyros to their limits and I have only been able to 'feel' the differences that changes make to the performance of the heli for less than half that time. I didn't really notice any difference with the Spirit Pro and it was only when I bought my 700X and chose the Bavarian Demon (the Axon was Steve's recommendation) to give me an opportunity to benefit from what seemed to be a better software interface after looking into it.
When I queried the B.D. guys regarding the different setup (6 degrees vs 9-10 degrees) in their instructions, the chap told me that I could set it for whatever I wanted but presumably they expected 9-10 to be the limit. Since then, I've used this approach with my Spirit Pro. Funnily enough, I was also using 70% D/R & 30% Expo in my Tx., too, but I noticed that when I did the checks on the PC with that value for the D/R, I was only getting 4.5 degrees of cyclic. My conclusion was that the 70% was restricting the gyros ability to deliver the 6 degrees that were programmed in.
The first part of my testing during the maiden was to leave the D/R and Expo alone. Of course, the heli is massively sensitive to the slightest twitch of the stick but I counteract this by using a high 'Dead-band' setting in the gyro. I can change settings via my Jeti Tx. in the field, so this helps tremendously. I currently have 70% D/R in the Tx. and 10 degrees cyclic geometry rather than 6. During my rather short testing period, I saw a massive increase in the stability of the hover from pre-overhaul performance. I was only testing for a little under 24 minutes of flight time, so early days in my opinion to say definitively.
Flight style is a bit more difficult really as I don't think my personal style (boring) is catered for anywhere. I don't think it's possible for anyone to judge the differences until they're capable of performing the most crazy stunts anyway. I tried the coaxial setting and it didn't 'feel' any different to me. Maybe I need a scale starting at -10 to see any difference or possibly an 'Auto-pilot' setting
Finally, I never use any D/R or Expo on the collective stick, only on the cyclic stick.
