Hi Steve, thanks for your perseverance on these issues. I want to have my understanding clear before publishing a video of the setting up process asap.
I'm setting up to reconnect my Spirit Pro to the laptop to do some more investigation tomorrow.
My understanding is that negative gain values on any gyro is called 'Normal (or Rate) Mode'. Provided I have a negative value in the Tx. under the transmitter's method of adjusting it (whatever that might be for a particular Tx. make) then the Spirit Pro unit will follow this value to activate and follow whatever stability option the 'Stabi' Tab is selected for in the software (apart from when it's 'Disabled' of course). This leaves the user to create a method for switching the 'Stabi' function on or off in the simplest of examples. If the user wants to have different options available, this can be via programming in different banks or in different flight modes. This will also vary depending upon the make of Tx. being used. However, the 'Rescue' function must be activated by a switch (preferably a spring switch) and only activated by the pilot for a minimum of time until the heli is once again out of danger and ready for another attempt at the new manoeuvre or to land safely and change pampers.
My testing tomorrow will focus on what looks like my Spirit Pro is in fact defaulting to a 'Heading Hold' positive value despite it receiving a minus 70% setting from my Jeti DC-14. Yesterday evening when I went to the field, I was able to move the tail rotor to left and right and it stayed there when I released the rudder stick. I could move it slowly to the centre position and a bit further right or left. It didn't snap back to a central position, which it did when connected to the laptop during my last setup session.
The heli displays distinct stabilisation reactions i.e. when it receives a small cyclic command and the stick is released, it rocks back to its previous position. If it receives an increased command and released, it will slow down but continues in the selected direction but slows down significantly leaving plenty of time to give an opposing command to stop its progress. I can't see the display that shows what the gyro is receiving from my Jeti's interface.
Of course, what could be happening is that the negative value is activating the function but the gyro's interpretation of it for its gain function is as an equivalent positive 'Heading Hold' value. This would explain what I'm seeing at the field.
Regarding the Wi-Fi, I still don't understand what mechanism and how the unit receives it's signals. When I can't see a Wi-Fi network on my mobile, it communicates via 3G or 4G, whichever is available. What do you mean by "It's just a way for the Spirit to communicate with other wifi enabled devices."................... such as what? It must at least have a screen and an application (provided by Spirit) for it to work. What displays are seen? Are they identical to what I see via the software installed on my laptop (v2.4.1)?
Thanks again for your patience.
