Heliman450
Hi all, looks like I've found the solution to an earlier thread here.
The Spirit Pro unit is making a conversion of the negative value from the Tx. to positive. See the three photos below that show the gyro status underneath the indicator band. When I made a change in the function to 'Rescue (Normal)' the blades snapped to + 5.5 degrees with a setting of 40% for the 'Rescue Collective Pitch', which increased to 7.0 degrees when I increased this to 50%.
I then changed the gyro setting to give +70% rather than -70% and the blades returned to my current minimum pitch curve setting for -1.6 degrees. The display returned to show display #3 with the gyro status showing 67% 'Head Lock'.
This means that I now have to find out how to pulse the -70% signal to activate the fixed blade pitch signal (now back to 40% and +5.5 degrees). I now know that there is no stabilisation function associated with the 'Rescue (Normal)' function.
![03S_Spirit Diagnostic Tab.jpg 03S_Spirit Diagnostic Tab.jpg](https://www.rc-help.com/data/attachments/13/13651-66e0ad705bd15df6a1edf455af57d2b8.jpg)
![01S_Spirit Diagnostic Tab.jpg 01S_Spirit Diagnostic Tab.jpg](https://www.rc-help.com/data/attachments/13/13649-e8057dac4c19630931332342894c1462.jpg)
![02S_Spirit Diagnostic Tab.jpg 02S_Spirit Diagnostic Tab.jpg](https://www.rc-help.com/data/attachments/13/13650-3161b3cbc52b9a422ce1bd1d7a453a14.jpg)
